September 21, 2008 at 4:13 am #133562
Hi Joomlart Team:
I just installed the JA Sargas template for Joomla 1.5 on one of the sites I’m working on. I using Joomla 1.5.7.
I’m encounter two problems:
1. Top navigation menu does not center nicely under banner in IE7 while in FireFox it looks fine. See attached pic.
2. When using CSS menu, and menu drops … there’s a white bar going across menu. See pic. Looks like to be the white background for the section title.
I’ve checked the template.css and index.php but can’t figure out what is causing the problems. Can you please help?
site: http://www.lhsofhawaii.org/joom15
Thanks in advance for your replies.:)
- Sherlock Friend
Sherlock
- 2478 times in 2162 posts
September 23, 2008 at 8:31 am #271832Hi abishai !
to fix menu bug, you can do it following way below :
Go to admin >> extensions >> plugins manager –> select mos_sifr plugin and set it to disable .Sherlock FriendSherlock
September 23, 2008 at 8:41 am #271835About error in IE 7 , please open template.css file in templates/jasargas/css folder, find following code section at about line 747 :
.wide #ja-sh {
width:580px;
change to :
.wide #ja-sh {
width:auto;
AuthorPostsViewing 3 posts - 1 through 3 (of 3 total)This topic contains 3 replies, has 2 voices, and was last updated by Sherlock 16 years, 3 months ago.
