September 23, 2013 at 10:47 am #190830
When I select the image for the item to pop-up (in K2) the navigation arrows on the left and right side of the item do not display?
When I select any other part of the item (title text comment) everything function good
Also with (youtube) media embed the arrows are their.Also when I select the item the page turns dark (see image)
phong nam Friend
phong nam
- May 2015
- 974 times in 888 posts
September 24, 2013 at 5:38 am #506832Hi ministryhouse,
Generally, the pre,next buttons are created to appear on the popup view of articles/item on the category view only, more important that the K2 category is being shown contains at least 2 active items. In addition, when you refresh the article/item page or open article in new tab, the template will load the normal page without these buttons.
<blockquote>when I select the item the page turns dark (see image)</blockquote>
It seems that the mega-dim effect got the problem on your website. In this case, it will be better that you send me PM with your website’s credentials, so that I can check and give you any suggestion then.Note: Make sure you do include the front-end access in PM since I see your website is offline now.
Viewing 2 posts - 1 through 2 (of 2 total)This topic contains 2 replies, has 2 voices, and was last updated by phong nam 11 years, 2 months ago.
