  • rahulxx Friend
    #159880
    I am creating a template using JT 3
    I am realizing that it is much easier then i thought 😀
    but today i got some problem using jquery
    i am using alfa Registration extension for registration process, its nice
    but on registration page mega menu and component did’nt work.
    i thought to modify the extension using jQuery.noConflict();
    and upgraded to jquery 1.5
    now component is working but menu still not working
    please suggest a good solution plz
    dunglq Friend
    #375731
    <em>@rahulxx 219900 wrote:</em><blockquote>I am creating a template using JT 3
    please suggest a good solution plz</blockquote>
    If you want to using jquery in J!1.5 (with mootools), please dont using $ with jquery, after add jQuery.noConflict(), with function use jquery change $ to jQuery
This topic contains 2 replies, has 2 voices, and was last updated by  dunglq 13 years, 11 months ago.
