  • robyrom Friend
    #198245
    Trying to add a new column to the megamenu I have got messed the whole stuff. Starting with 2 columns now I have only one containing one after the other the two submenus I have. This is a screenshot
    I don’t find the way to enlarge the column containing the two submenus except to set a width in pixels: is this the correct way to follow?
    1. foto01
    swissa Friend
    #536955
    If you highlight the blue box shown just simply add a value in px into the ‘Submenu Width’ above it. Use for example 500px and see what happens. You can do this for all sub menus too.
    fmfame Friend
    #537236
    Hi robyrom,
    just play with the megamenu and try to click on the menu containers there, here you can change column width.
    And if you have much submenu content you can click on this BUTTON:
    Then here you can manage the module containers by clicking and changing submenu width..
    And here in Documentations there are lots of screenshots for setting our cool megamenu.
    http://t3-framework.org/documentation/menu-system
    Hope this helps
    1. Bildschirmfoto-2014-05-30-um-15.08.36
This topic contains 3 replies, has 3 voices, and was last updated by  fmfame 10 years, 6 months ago.
