patrik76 Friend
patrik76
- August 2010
October 8, 2010 at 5:52 am #155060Hi
I have encountered a few issues on my site.
I need someone who can help me check them ( find out causes and fix them )
Here are a few issues: http://dl.dropbox.com/u/2431565/Fix/Ledarskap%20problems.docxThere might be more that we have overlooked.
Need help on this. Any suggestions would be great.Thanks
Don Lee FriendDon Lee
- March 2010
- 274 times in 238 posts
October 8, 2010 at 7:14 am #358164Hi,
I’m willing to help but could you please clarify the issue by another post w/o any document?
patrik76 Friendpatrik76
- August 2010
October 8, 2010 at 9:09 am #358199Hi DongIt
Thanks for the reply.
Here are a few of our issues:• When asking for new password http://www.ledarskap.biz/lost-password.html there is a code mailed – it does not work when the member add it.
• The title says CSR for some reason – CSR is a category. It should say the authors name.
http://www.ledarskap.biz/csr.html?authorid=191 (The url is also wrong – should not include “csr”)• When adding new content sh404sef is writing the wrong url. EX:
http://www.ledarskap.biz/foersaeljning-amatoerernas-sista-arena.htmlö should be o
ä should be a
å should be a
Ö should be O
Ä should be A
Å should be A
instead of ae, oe, etc• The latest article has no related articles: http://www.ledarskap.biz/foersaeljning-amatoerernas-sista-arena.html
Eventhough i used same keywords for these two:
http://www.ledarskap.biz/5-steg-till-framgangsrikare-saeljledarskap.html
http://www.ledarskap.biz/vikten-av-stark-saeljledning-foer-framgang-i-affaerer.htmlIt should have related both in module to the right in “RELATERADE ARTIKLAR” and under the article with thumbnails showing. They are taken from iJoomla Magazine.
• Why are there two menus marked as the default menu in joomla admin?
• I change “You are here” in the breadcrumb but it does not show Swedish letters – it should be “DU ÄR HÄR:” and also change “HEM” to “START”.
these, so far, are the issues that we have on our site.
Can you help us these?
- 1334 times in 848 posts
October 11, 2010 at 9:00 am #358406Hi patrik,
To me it seems that all the problems you have enlisted up there are more of joomla related and are not coz of using JA products (extensions / templates). I am afraid we would not be able to provide active help on these issues.
To confirm if the problems are related to the Teline template, please switch to other template and see if the above problems are resolved.
I do believe that its the SEF component which is causing the trouble. Did you try disabling it and checking for issues ?
Arvind
This topic contains 5 replies, has 3 voices, and was last updated by patrik76 14 years, 2 months ago.
