  • hjalte1983 Friend
    Ninja Lead Moderator
    #469971
    I fixed the error at mega.js file. Please check your site again. As i did many changes on it but you can compare betwwen “mega.js” and “mega_old.js”
    This is path <blockquote>/templates/ja_university/js/menu/mega.js</blockquote>
    hjalte1983 Friend
    #470005
    ahh awesome you fixed it 🙂
    But my site is very slow loading now ??
    just timed out on this work computer… but when i refresh and im on the site, there is no problem and its fast.
    but the first time loading.. it takes ages ???
    tfosnom Friend
    #470009
    Hi H
    did you remember to turn the optimise JS and CSS back on after all the trouble you had (join & minify etc in template manager?)
    that;s is supposed to make site a bit faster
    Blessings Shannon
    hjalte1983 Friend
    #470012
    yeah….
    Enable Development Mode = YES
    Enable Template Information = YES
    Optimize CSS = join & minify & compress
    Optimize JS = join & minify & compress
    Optimize Folder = t3-assets
    SEO options :
    Yes
    No
    No
    No
    its same options as my other site rfkkbh.dk
    and that is not that slow.. but my rfkkbh.dk still have the big banner bug 😀
    #470038
    @hjalte1983: I fixed the problem on mega menu on your site. Please check and confirm the same!
    hjalte1983 Friend
    #471353
    Hey Ninja lead, can you do the same on my other site.
    http://www.rfkkbh.dk
    i cant just copy the file from /templates/ja_university/js/menu/mega.js from rl-rfk.dk. that doesnt work.
    the password is the same on rfkkbh.dk
    best regards
This topic contains 7 replies, has 3 voices, and was last updated by  hjalte1983 12 years ago.
