  • YitzySvei Friend
    #117526
    Everything works just have one last minor problem on bottom right corner of my website theres a picture that says W3C|XHTML 1.0.If you click it your transferred to validator.w3.org.I must have this picture removed anyway do to it?
    I tried delting the image from images folder ,but it just showed an x on the bottom of the page .Im sure somone knows how to remove it:)
    Hung Dinh Friend
    #211406
    Please remove the html codes in the index.php file of the template
This topic contains 2 replies, has 2 voices, and was last updated by  Hung Dinh 18 years ago.
