  • joomlanthony Friend
    #938979
    Hello I need some help, how do you remove the "design it" link that appears when you place a picture on the lp-top-1 position?
    thank you for your help
    HI
    May I know which template are you using? and screenshot highlighting the part you want to remove?
This topic contains 1 reply, has 2 voices, and was last updated by  Saguaros 8 years, 6 months ago.
