  • ssuresh Friend
    #149718
    Hi !
    I need to remove the lines in the Columns displaying articals….
    For Example : See The Attachment
    I need to remove the lines which i marked in Yellow color……
    Thanks in advance…..
    1. Lines
    histeriks Friend
    #337288
    ssuresh;170719Hi !
    Hi ssuresh,
    please, open file template.css located in the css directory of your template, and on line 252 find this:
    .article_row {
    border-bottom: 1px solid #ddd;
    padding-top: 15px;
    padding-bottom: 15px;
    change it to this:
    .article_row {
    padding-top: 15px;
    and the separator line should be gone.
    Good luck 🙂
    ssuresh Friend
    #337463
    Hi histerix !
    Thanks…
This topic contains 3 replies, has 2 voices, and was last updated by  ssuresh 14 years, 8 months ago.
