  • dkabbey Friend
    #168971
    Does anyone know why my site suddently becomes like this? http://www.cheetahgeneration.com
    Where do I go to fix it?
    Thks
    Manos Moderator
    #415070
    can you please check if /images/resized folder is there? or if joomla can have access to write on this folder? You can also check this from the backend (admin panel ) .
    It looks to me like there is a permission error!
    Manos
    Update: Turn SEF off and your site will function as it should! OR rename htaccess.txt to .htaccess
    dkabbey Friend
    #415080
    If I am to send you the login and username, could you please check it out for me?
    Manos Moderator
    #415081
    Yes,
    You can send me your login credentials via PM !
    Manos
    dkabbey Friend
    #415110
    Thank you so much!!! I can see something now! Also too “Latest News” image are wierd!! Any solutions to this?
    Manos Moderator
    #415126
    I think that everything works fine now on your site, can you please confirm that from your side also?
    Manos
This topic contains 6 replies, has 2 voices, and was last updated by  Manos 13 years, 3 months ago.
