  • akeem11 Friend
    #179173
    Can some one please help me to find out how to add a new module position in JA Norite.
    Or help me add space between the two modules in the same position (Absolute position in JA Norite), so that one could be on the
    far left and one on the far right.
    Please see the attached jpeg.
    Thanks so Much,
    -Akeem.
    1. PIC-OF-SITE
    #461383
    Hi akeem11,
    You can open the file of templatesja_noriteblocksheader.php to add your new module position there, For example if you want to add new module position name user99 you can add a block of code like this
    <div class=”ja-user99″>
    <jdoc:include type=”modules” name=”user99″ />
    </div>
    Now you have a module position name user99 to assign your modules there.
    akeem11 Friend
    #461519
    Hi Thank, I will try this.
    Another question?
    How do I remove the Top menu bar, Its in the way and duplicates the menu on the left side. I dont want the menu on top at all,
    please help, Thanks.
    -Akeem
    akeem11 Friend
    #461572
    <em>@Sherlock Holmes 330703 wrote:</em><blockquote>Hi akeem11,
    </div>
    Now you have a module position name user99 to assign your modules there.</blockquote>
    I tried this. It created the module position, however its not on the top right side of the page.
    Please help Thanks.
    -Akeem
    http://www.barrybazza.com
    I want the translation flags on the top right.
    #461580
    Hi Akeem,
    You can open the file of templates/your_template/css/template.css and adding this css
    .ja-user99 {
    float: right;
    position: relative;
    top: -55px;
    width: 40px;
    I hope it helps !
    akeem11 Friend
    #462016
    Hi Serlock,
    You are “Joomla god”, you have answered my request graciously and with great efficiancy. I now have one more question.
    I would like to put the “enter site module” lower on the page. Please see the attachment.
    This module position is called “user98” it in the footer block. I just want it to be more towards the bottom of the page as in the
    snap shot. Thanks so much,
    -Akeem
    1. siepic-2
    #462104
    HI Akeem11,
    You can open the file of templates/ja_norite/css/layout.css look for this css
    #ja-footer {
    clear: both;
    Change it to
    #ja-footer {
    bottom: 0;
    clear: both;
    position: absolute;
    I hope it should help !
This topic contains 7 replies, has 2 voices, and was last updated by  Sherlock 12 years, 5 months ago.
