jimcapraro Friend
jimcapraro
- September 2008
- 4 times in 1 posts
December 28, 2010 at 4:34 pm #157971I’m creating a site for a client using JA Corona. The client wants the content boxes of the site to be separated by white borders in a grid-like fashion, similar to that found on this site: http://www.liscjacksonville.org.
I am getting close to accomplishing this, but there are a few instances in which I cannot figure out how to get my white borders to extend the full length of the box, line up correctly, etc. I’m pretty sure that it’s a matter of adjusting margins and padding in the template CSS file, but I’m stumped as to which paramaters to adjust. Here’s the site I’m working on: http://cdwebsites.net/corona/
Please help! I’m using Joomla 1.5 and the most recent version of the JA Corona template.
Thanks!
aman204 Friendaman204
- January 2010
- 418 times in 356 posts
December 28, 2010 at 6:14 pm #368970Try add this at end of template.css file ::
#ja-newsflash-janflh-modid46 {height:175px !important;}
Change this::
#ja-container-top {template.css (line 552)
background:none repeat scroll 0 0 transparent;
padding-top:20px;
}to
padding-top:0;
}You can make in similar value change here for padding::
#ja-container-bot {template.css (line 561)
border-bottom:10px solid #FFFFFF;
padding-bottom:20px;
}1 user says Thank You to aman204 for this useful post
jimcapraro Friendjimcapraro
- September 2008
December 28, 2010 at 7:42 pm #368993Thank you! That solved the problem in two of the spots. Two of the spaces are still there (see below). Any ideas?
Thanks again
- November 2014
- 3854 times in 3563 posts
December 29, 2010 at 2:42 am #369041Hi jimcapraro,
Please add this at the bottom of template.css
#ja-topslwrap .ja-box-left{
margin-left: -20px;
it should work.
Sincerly.1 user says Thank You to Ninja Lead for this useful post
- September 2008
December 29, 2010 at 3:04 pm #369149Thank you!
AuthorPostsViewing 5 posts - 1 through 5 (of 5 total)This topic contains 5 replies, has 3 voices, and was last updated by jimcapraro 14 years ago.
Need help adjusting borders, padding, margins, etc.
