  • jcmendizabal Friend
    #166185
    http://www.joomlart.com/forums/topic/conflict-with-unregistered-users/ I need urgent help with this…Why does Joomlart Support does not care about a customer problem? Yes it is my testimonial that I feel abondoned by you guys, please it is urgent!!!
    chavan Friend
    #400621
    Do you Need the Unregister Users also to comment your Contents ?
    jcmendizabal Friend
    #400625
    hi finally a response…take a look at this page http://www.fightnatic.com/index.php/Internacionales/fedor-emelianenko-comenta-su-enfrentamiento-crucial-contra-dan-henderson.html this is an interior page which has javascript errors check it in firebug or in the web developer toolbar and you´ll see, I want this to be error free…what I was pointing out is that this error only appears to unregistered users.
    chavan Friend
    #400798
    those are negotiatable
    jcmendizabal Friend
    #400799
    What do you mean? I am not a developer so please clarify that statement
    chavan Friend
    #402204
    those might be Just warning and can you provide me a New Url, since the previous one doesn’t work.
    emiliaw Friend
    #412002
    I am sorry that you seem to have had a bad experience with the service here. To be perfectly honest, this is the first time I had heard of any negative feedback concerning customer service. Could it be that you are just being impatient, or have unrealistic expectations? Everyone I know who uses Joomlart, has nothing but good things to say, just thought I would state that for the record. As a matter of fact, I was recently held up on this web based payroll system I was working on
    (similar to Nashville time and attendance), due to an issue with the software. The customer service rep was very prompt in his responses, and was extremely helpful in resolving the issue, and thankfully, I was able to finish the project on schedule.
    TomC Moderator
    #423471
    Also, sometimes all it takes is a little PATIENCE, PRACTICE & PERSEVERANCE
This topic contains 8 replies, has 4 voices, and was last updated by  TomC 12 years, 12 months ago.
