August 15, 2010 at 9:09 pm #153559
Hi all,
Can anyone help me to integrate the Cufon font replacement script in the blank template?
I managed to integrate it successfully in a template on the T3 v1 framework. But everything has changed now with the T3 v2 framework.
Thanks in advance,
Stevecssyeah Moderatorcssyeah
- June 2006
- 121 times in 81 posts
August 16, 2010 at 3:02 am #352756Hi lo30sopa6,
Why you don’t use Google font? we removed the CUFON in T3v2. If you want to use cufon in blank template, you can copy some script from the T3 v1 to the T3 v2.
If you can’t do it, i can help you. 🙂
1 user says Thank You to cssyeah for this useful post
August 17, 2010 at 2:07 am #352881Hi Trungch,
First of all thanks for your reply.
The reason for me to not use the googlefont option is mainly because most of their fonts don’t render nicely across all browser platforms.
And besides that I would like to use some other kind of fonts, which Google doesn’t provide. I allready managed to get @Facefont working in the template, but I still prefer Cufon for headings & titles and stuff.
In order to get Cufon working: If you could show me which code I should copy and where I should paste it, I would be very grateful 🙂 And I think a lot of other Joomlart-members as well!
Greetz,
SteveSaguaros ModeratorSaguaros
August 20, 2010 at 7:56 am #3532431) you copy the head.php file from the : pluginssystemjat3base-themesdefaultblocks and put it into the templatesJATEMPALTEblocks
2) you get the folder: templatesja_purityiilibscufon and put it into the templatesJATEMPALTEjs folder
3) you open the head.php file ( # at step1 )
and add the following code at end of file:<script language=”javascript” type=”text/javascript” src=”<?php echo JURI::base();?>/templates/<?php echo $this->template ?>/js/cufon/js/cufon-yui.js”></script>
<script language=”javascript” type=”text/javascript” src=”<?php echo JURI::base();?>/templates/<?php echo $this->template ?>/js/cufon/fonts/Museo_500_400.font.js”></script>
Cufon.replace(
‘.componentheading, .contentheading, .ja-zintitle a, div.moduletable h3, div.moduletable_menu h3, div.moduletable_text h3, div.moduletable_highlight h3’,
{ fontFamily: ‘Museo 500’ }
Cufon.replace (
‘.logo-text h1’,
{ fontFamily: ‘Museo 500’, color: ‘-linear-gradient(#999, #000, #999)’, textShadow: ‘#ccc 1px 1px’ }
</script> -
This topic contains 4 replies, has 3 voices, and was last updated by Saguaros 14 years, 4 months ago.
