  • photosbymaximo Friend
    #951295
    I have the JA Magz II template installed and on my site and now I am getting a fatal error when I click some articles.
    Error: Fatal error: Class ‘JATemplateHelper’ not found in /home/pkmag/public_html/templates/ja_magz_ii/html/mod_articles_latest/default.php on line 25
    Pankaj Sharma Moderator
    #951301
    Try this
    Go to /templates/ja_magz_ii/html/mod_articles_latest/default.php on line 25
    And add this line in the line 17 > >> http://prntscr.com/ap4u18
    Let me know if it helps .
    #951305
    I did that and it did not work. The Error is still there.
    #951315
    I fixed it directly on your site , added the same code as in screenshot
    // Template helper
    JLoader::register('JATemplateHelper', T3_TEMPLATE_PATH . '/helper.php');
    Issue solved
This topic contains 3 replies, has 2 voices, and was last updated by  Pankaj Sharma 8 years, 4 months ago.
