robnob Friend
robnob
- October 2011
- 2 times in 1 posts
April 19, 2012 at 3:27 pm #176293Please see the attached picture…
I am looking to change the menu’s background color from being transparent to white (#ffffff)
In the process of trying to edit the CSS file (templates/ja_methy/css/menu/mega.css) i somehow added these small boxes in the drop down.May someone help point me how to get rid of the small boxes and add a white background to the menus top ?
Thank you!
khoand Friendkhoand
- February 2011
- 1166 times in 1060 posts
April 19, 2012 at 4:02 pm #449143<em>@robnob 314776 wrote:</em><blockquote>
Thank you!</blockquote>
You go to Template manager,choose JA Methys template, then change CSS Optomize fieds to NO, so I can check how and where to customize for you.
Could you give me a link to your page as you said?robnob Friendrobnob
- October 2011
khoand Friendkhoand
- February 2011
April 19, 2012 at 4:24 pm #449147<em>@robnob 314787 wrote:</em><blockquote>I have CSS Optimize off.
The page is here.
Thanks</blockquote>
– You replace this code from /templates/ja_methys/css/menu/mega.css
li.haschild-over a.mega span.menu-title {
background-image: url(../../images/arrow-down-02.png);
with
background-image: none;
– You find this code from /templates/ja_methys/css/template.css
#ja-mainnav {
position: absolute;
right: 5em;
top: 100px;
border-top: 1px solid #E5E5E5;
border-bottom: 5px solid #111;
z-index: 999;
background: white; < add this line
}1 user says Thank You to khoand for this useful post
robnob Friendrobnob
- October 2011
April 19, 2012 at 5:02 pm #449162Wow – worked like a charm “THANKS”
If you have additional time (i am a CSS Noobie – trying to learn it)
Do you know how to set a margin to the left of the far left menu item (HOME) – so it’s not right at the edge of the white background? and;
Do you know how to center my K2 login module on the LOGIN menu? (my assumption is that i have to set a margin to the left of module)khoand Friendkhoand
- February 2011
April 19, 2012 at 5:39 pm #449168<em>@robnob 314805 wrote:</em><blockquote>Wow – worked like a charm “THANKS”
Do you know how to center my K2 login module on the LOGIN menu? (my assumption is that i have to set a margin to the left of module)</blockquote>
You give me a snapshot with your comment to illustrate your idea. I will help you.robnob Friendrobnob
- October 2011
April 19, 2012 at 6:28 pm #449183Thanks in advance… These actually may be pretty easy (or atleast the 1st one)
robnob Friend
robnob
- October 2011
April 24, 2012 at 4:19 pm #449980I was able to fix the first part of the question by adding margin-left… but i still can’t figure out the K2 user module…
Any ideas?khoand Friendkhoand
- February 2011
April 24, 2012 at 4:38 pm #449988<em>@robnob 315807 wrote:</em><blockquote>I was able to fix the first part of the question by adding margin-left… but i still can’t figure out the K2 user module…
Any ideas?</blockquote>
You add the code into /templates/your_template/css/template.css
div.k2LoginBlock {
padding-left: 20px;
robnob Friendrobnob
- October 2011
April 24, 2012 at 5:21 pm #449995Fantastic! I need to do my homework and learn more CSS. Thank you.
robnob Friendrobnob
- October 2011
April 24, 2012 at 11:09 pm #450021Khoand it works perfect for the login module but it doesnt work once you’ve actually logged in. It goes back. any ideas?
<em>@khoand 315815 wrote:</em><blockquote>You add the code into /templates/your_template/css/template.css
div.k2LoginBlock {
padding-left: 20px;
</blockquote> -
Viewing 11 posts - 1 through 11 (of 11 total)This topic contains 11 replies, has 2 voices, and was last updated by robnob 12 years, 8 months ago.
