  • turgut Friend
    #136800
    Hello
    On this web site http://www.cukurova-idek.org I just changed three pictures; it was OK. However on the right and left (background of logo), a blackish background left. I wonder how I can replace these blackish background with the part of the picture seen on the header.
    Turgut
    rdevereaux Friend
    #285121
    In the source files on the download page, you will find both sides of the menu that you can pull into photoshop or any graphics editor and remove the background from it. Your picture should show up under it.
    Use caution when using pngs with explorer. It will not show up correctly. Try saving it as a gif file. Explorer likes those better! 🙂
    Hope that I helped.
    turgut Friend
    #285132
    appreciate the response. managed to fix it by trying and fail.
    Turgut
    rdevereaux Friend
    #285134
    Glad that you got it to work! 🙂
This topic contains 4 replies, has 2 voices, and was last updated by  rdevereaux 15 years, 11 months ago.
