  • folamour Friend
    #201805
    hi folks, we have a new law in europe that need to ask to user to accept cookie on website, i that warning message is not displayed we can face a fine of 300.000 € so i’ll need to adapt that script
    https://opt-out.ferank.eu/en/
    on ma ja purity II template,
    but we have seeked and seeked many file, and found several occurence but its never the good
    can you tell me where to add the
    <head>
    code
    </head>
    and
    <body>
    code
    </body>
    i’m running JAT3 2.5.5
    thanks a lot
    folamour Friend
    #551713
    I have found that thread http://www.joomlart.com/forums/topic/installation-of-google-analytics/#post-378668
    but that don’t work, i’ve checked ctrl u all seem ok
    and file is well loaded in firebug
    Eragon H Friend
    #551895
    The guide in the above thread is right.
    You can try to clear the cache (JAT3 cache, Joomla Cache and Browser cache) to see the change happen
    If script is loaded well but nothing showed, you should check the script.
    You also can use extensions such as Cookie Pro for this such purpose: http://extensions.joomla.org/search?q=Cookies
This topic contains 3 replies, has 2 voices, and was last updated by  Eragon H 10 years, 1 month ago.
