Viewing 15 posts - 16 through 30 (of 38 total)
  • Manos Moderator
    #518764
    I need access to phpmyadmin (it will be better if you can pm me cPanel access) so i can try to help you.
    Manos
    vaxt11 Friend
    #518765
    how do i do that?
    Manos Moderator
    #518766
    Click on my name (right above my avatar) and use “Private Message”
    Manos
    vaxt11 Friend
    #518767
    I just sent pm. Thanks.
    Manos Moderator
    #518768
    Ok!
    Allow me some time to work on your site, i will update here as soon as i can come up with any results.
    Manos
    vaxt11 Friend
    #518769
    Great thanks so much.
    Manos Moderator
    #518771
    You db issue has been fixed!
    Checking about the recaptcha issue
    Manos Moderator
    #518773
    Here’s what i found about recaptcha and Joomshoping -> http://www.webdesigner-profi.de/joomla-webdesign/joomla-shop/forum/posts/11/817.html?lang=de
    Maybe that can help you.
    Manos
    vaxt11 Friend
    #518778
    Thanks! You are my hero! I’ll try to make sense of your joomshopping link. I’m not a programmer but I’ll see. If you have any ideas please jump in. Thanks again.
    Jonathan
    vaxt11 Friend
    #518881
    How did you update without problems? Everything I see says not to do.
    Manos Moderator
    #518886
    I am not sure i understand your question what do you mean ?
    vaxt11 Friend
    #519121
    How did you update joomla version with out problems? I’ve not wanted to update as all I’ve read has said that when you do problems occur.
    Manos Moderator
    #519122
    Well i haven’t you did that and then your problems began, i only fixed those problems.
    My guessing is that you tried to update JA software using standard Joomla Update functions and that didn’t work.
    You should use JA Ext Manager for doing so.
    Manos
    vaxt11 Friend
    #519124
    I’ll try that. Thanks so much for your input and help.
    JDT
    vaxt11 Friend
    #520663
    Is there any way to switch back to previous joomla version? Since updating we have had nothing but problems. The site is once again screwed up. We didn’t change anything in the template but the site has lost design. We do have a recent backup but will still lose billable hours. This update is costing us money. Not happy with update or with joomlart as feel this should not be happening.
This topic contains 38 replies, has 3 voices, and was last updated by  Manos 10 years, 11 months ago.
