Manos Moderator
Manos
- February 2014
- 633 times in 576 posts
January 31, 2014 at 6:29 pm #520665Hi,
I am not sure if there’s a way to downgrade Joomla without problems. As for your problems i am afraid that i will have to prove to you that the problem is your server.Can you please let me know if i am allowed to create a copy of your website on an other server ?
Manos
1 user says Thank You to Manos for this useful post
vaxt11 Friendvaxt11
- February 2012
January 31, 2014 at 6:31 pm #520667Yes you can create copy if that will help solve this issue. What do you need to do?
vaxt11 Friendvaxt11
- February 2012
February 3, 2014 at 3:33 pm #520965Will you have time to look at this problem? I need to either figure out or restore backup and redo work done. Please let me know and thank you for your time.
Jonathanvaxt11 Friendvaxt11
- February 2012
February 3, 2014 at 3:47 pm #520966Below is reply from hosting server:
I have looked into this for you and found that your site is not generating any errors when loaded. It appears that your theme may not be compatible with the new version of joomla. Please check you theme and any plugins to make sure they are up to date and try re-publishing your site.
If you have any questions or comments please let us know.
Best regards,
Christopher F.
Linux Systems Administrator
HostGator.com LLC
http://support.hostgator.comHayden A FriendHayden A
- April 2010
- 54 times in 53 posts
February 4, 2014 at 8:16 am #521067@ vaxt11,
<blockquote>”but the site has lost design”</blockquote>
>> You can try to switch ON / Off the Optimize CSS and JS option in template manager (Backend > Template manager > JA Tiris > T3 options
http://easycaptures.com/fs/uploaded/635/3708094606.png
Clean JAT3 cache and refresh your site to see how it goes.
Additionally, in order to confirm the issue comes from our template or not, you can try to switch default template (JA Tiris) to another standard template of Joomla like Beez to see if problem persists or not.
1 user says Thank You to Hayden A for this useful post
vaxt11 Friendvaxt11
- February 2012
February 4, 2014 at 4:12 pm #521136The site design is restored but unfortunately the slideshow mod does not work. I’m also checking others to see if they function. Can you help? Also, will we continue to have problems with the site? Thanks.
- April 2010
February 5, 2014 at 9:42 am #521286@vaxt11,
On your site http://192.185.139.211/~tempbar/, I checked slideshow module and see it works fine.I guess you don’t see 3 blocks under slideshow, you need to login Backend => Module Manager => Module JA Side News (position sidesnews) and choose category you want to be selected => Save and pls clean cache, See screenshort for reference:
http://easycaptures.com/fs/uploaded/636/8481273710.pngIt would be best if you can send me screenshot to illustrate the issue at your end.
This topic contains 38 replies, has 3 voices, and was last updated by Manos 10 years, 11 months ago.
