  • seelife Friend
    #178462
    Hi Folks, I had help some time ago to place a JATabs module into my Teline4 and it is working, under each Tab, I publish “bulletins”.
    But I would like a “Title” to appear above the Tabs so that the module area is clearly named for readers to go to.
    I know it can be done, but don’t quite have the experience to fix it. I have been told that I can publish a new custom html module to the same area and then style it. Ive tried but am not succeeding.
    Can someone kindly assist me with getting it working.
    The site is : http://www.micexchange.com/MJ/ and the tabs are half way down on the left hand side (Agencies, Venues etc) – I would like a Title just above the tabs
    Thanks and regards for anyone that can assist.
    HeR0 Friend
    #458711
    Hi Seelife
    It is a module, hence you can totally enable to show Title of the module. What do you think about that?
    Regards,
    Manos Moderator
    #464726
    As far as i can understand you can achieve that by creating and publishing a custom html module, you must publish this above the JA Tabs module!
This topic contains 3 replies, has 3 voices, and was last updated by  Manos 12 years, 2 months ago.
