  • issay Friend
    #170762
    the problem is that , I changed my catagory order in back end in Content> Catagory Manager. but this does not reflect in newspro module in front end (iam using linear mode) .
    to be sure I checked my database table in myphp admin. and I can see my order in data base.
    and I found that the problem is with news pro module. because If I open linear module and save at , I can see my ordering in home front end.
    so in short, I have to Open the module and Save every time I re-order my catagories.
    note: I want to re order catagories verey often . reason is ,I want catagories with new articles to appear on top.
    So I need a soloution that I dont have to open the module and save.
    khoand Friend
    #424958
    You try edit module, set Caching is No Caching
    issay Friend
    #425259
    that didnt work. I tested it with Caching= Yes/ No . and cleared every cache. even browser cache/history.
    But my changes in catgory order does not appear on news pro , except If i open the module refresh it and SAVE it.
    khoand Friend
    #425362
    Could you give me username+password of your backend and ftp? I will check it.
This topic contains 4 replies, has 2 voices, and was last updated by  khoand 13 years, 1 month ago.
