  • gbelli Friend
    #911604
    I need to help to get the top header custom search component so that it does not stack up and use only a minimum of the screen viewing area. It is making it difficult to see products and make purchases. I am using joomla 3.4.4 and JA Cagox 1.0.2. and Genius Virtuemart Ajax Search – VM3 Edition – Deluxe Module. I provided a screenshot from my iPhone 6 Plus and supplied credentials.
    Thank you.
    1. IMG_1923
    As I can see that you customised the header much, you will have to check again the mockup of the header first and add style for that search extension.
    Check out this docs for more info about Bootstrap grid system
    Pankaj Sharma Moderator
    #912102
    There is not enough space to fit all the items .
    The maximum i tried to fit the item is like Here : http://prntscr.com/aqr08z
    For this you need to add below code in custom.css file
    @media (max-width:468px) {.t3-header {
        padding-top: 10px!important; }}
    Now go to the tpls/blocks/header.php file and set the value of col-xs for the main nav , header right like in my screenshot : http://prntscr.com/aqr0xc
    backend : http://prntscr.com/aqr15s
    Hope it helps .
This topic contains 2 replies, has 3 voices, and was last updated by  Pankaj Sharma 8 years, 9 months ago.
