proterra Friend
proterra
- July 2010
- 2 times in 1 posts
October 19, 2011 at 4:45 pm #169837Want to position a module position outside the template.
For teleine III I can realize this
http://www.joomlart.com/forums/topic/position-of-modules-not-available/But for Teline IV it didn´t runs. Have integrate an new module position called “headertop”. Integrate it over the block-name “top”: <block name=”headertop” type=”modules”>headertop</block>
But nothing happens. You can see it here: http://www.ecin.info
The Module with the content “test”jooservices Friendjooservices
- October 2014
- 1245 times in 1121 posts
October 19, 2011 at 4:52 pm #420251Hi,
Try adding this code to css/template.css and the module will go outside
.custom {
left: -12px;
position: absolute;
top: 31px;
Viet Vuproterra Friendproterra
- July 2010
October 23, 2011 at 10:49 am #420976That didn´t runs. It must something to make a position outside the template.
- October 2014
October 23, 2011 at 11:43 pm #421075Hi
Please make sure in css you have changed my .custom with your id / classname ?
Thank you
- July 2010
October 24, 2011 at 9:32 am #421169<em>@jooservices 278068 wrote:</em><blockquote>Hi
Thank you
Viet Vu</blockquote>test it, but nothing happens. You see it on the site: the image.
the topbar is still abovejooservices Friendjooservices
- October 2014
October 25, 2011 at 9:29 am #421446you can’t create a position outside of template, positions are always inside, what we can do is just to use css to move it off, you can check JA Events template for this, the pumpkin can fly every where within the page. I have tried my code above with your test module and it went off the layout. If possible, please take a screenshot and show me what you want clearly then I will try to help you again.
- July 2010
October 25, 2011 at 9:40 am #421452<em>@jooservices 278529 wrote:</em><blockquote>you can’t create a position outside of template, positions are always inside, what we can do is just to use css to move it off, you can check JA Events template for this, the pumpkin can fly every where within the page. I have tried my code above with your test module and it went off the layout. If possible, please take a screenshot and show me what you want clearly then I will try to help you again.
Viet Vu</blockquote>Have it realize with Teline III, think Teline IV is similiar:
http://www.turus.net -
This topic contains 7 replies, has 2 voices, and was last updated by proterra 13 years, 2 months ago.
