  • ccvpguy Friend
    #140591
    Hello;
    I am currently finishing new site which is based on Template Ja Teline II.
    Every file or folder is set to persmission 666 by default, I am not unix or Joomla expert, and I need assistance and your advice in order to secure the site before I launch.
    I know it sound silly but please advice me what folder/file shouldn’t be assigned 666 by default.
    I don’t have live site yet, it is in my localhost
    Thanks,
    John Wesley Brett Moderator
    #302535
    The standard, default permissions that get assigned to files and directories by the server are normally;
    Files = 644 and Directories = 755
    These permissions would allow, for files;
    644 = rw- r– r– = Owner has Read and Write
    Group has Read only
    Other has Read only
    and for directories;
    755 = rwx r-x r-x = Owner has Read, Write and Execute
    Group has Read and Execute only
    Other has Read and Execute only
    Hope this helps.
    John.
    Phill Moderator
    #302541
    If you have root acces and are the host then you probably do not have umask set properly if things are defaulting to 666.
    I believe this article explains it better than I could
    http://www.linuxforums.org/security/file_permissions.html
    ccvpguy Friend
    #302599
    <em>@phill luckhurst 125941 wrote:</em><blockquote>If you have root acces and are the host then you probably do not have umask set properly if things are defaulting to 666.
    http://www.linuxforums.org/security/file_permissions.html</blockquote>
    It seems this instruction i based on UNIX, am not sure how i can run Unmask on command line or windows. I am running WAMP, but all i did was intall the quickstart instruction from JA.
    Phill Moderator
    #302602
    Ah, you mentioned Unix in your first post so I assumed that is what you were talking about.
    Until you upload them file permissions for your server will not be set so no need to worry on the windows side.
    ccvpguy Friend
    #302606
    <em>@phill luckhurst 126015 wrote:</em><blockquote>Ah, you mentioned Unix in your first post so I assumed that is what you were talking about.
    Until you upload them file permissions for your server will not be set so no need to worry on the windows side.</blockquote>
    Thanks, that makes me feel comforable.
    Thanks,
This topic contains 6 replies, has 3 voices, and was last updated by  ccvpguy 15 years, 8 months ago.
