test melih
 melih
  • rfairman Friend
    #167295
    Hello again;
    In my template:
    http://bistro.canadianbeaconregistry.ca
    I would like to move the main menu, who’s online, testimonials.. that entire block to the left instead of the right.
    Is this done in the .xml?
    Thanks;
    Rhonda
    khoand Friend
    #405716
    <em>@rfairman 259052 wrote:</em><blockquote>Hello again;
    In my template:
    Thanks;
    Rhonda</blockquote>
    You login backend > Extensions > Template Manager > ja_bistro > LAYOUTS. Edit Default. You replace this code
    <block name="right1">right</block>
    with
    <block name="left1">right</block>
    TomC Moderator
    #414794
    <em>@knettwerk 270287 wrote:</em><blockquote>Rhonda –
    Did you use Magento to work with your site?</blockquote>
    Why would you ask this, as her question was posted within the JA Bistro section?
    Also, a quick look at the source code answers your question fairly quickly
    var tmplurl='/templates/ja_bistro/';
    Rhonda:
    Did khoand’s recommendation work for you ??
    TomC Moderator
    #414795
    In my template:
    Rhonda</blockquote>
    I also just wanted to say . . . . FANTASTIC JOB with customizing the JA Bistro template to fit your particular vision and needs.
    If we didn’t know better (since you posted this in the JA Bistro section – and most people wouldn’t bother to look at the source code – we would be hard pressed to recognize that as starting from the JA Bistro template.
    I LOVE seeing this kind of customization from the base template !!
    After all . . . A template is only a starting point . . . the magic is what YOU do with it from there.
    KEEP UP THE GREAT WORK !!!
This topic contains 4 replies, has 3 voices, and was last updated by  TomC 13 years, 4 months ago.
