  • folamour Friend
    #195386
    hi folks i’m trying to adjust my display, i’m on last release of ja purity II
    so i’ll try to adjust rigth and left colum,
    as told by joomlart,
    i’m modifiying
    default.xml
    in templatesja_purity_II_etclayout
    <blocks name=”middle” colwidth=”23″>
    and adjust size of left and rigth collum in templatesja_purity_iicsstemplate.css
    div#ja-mainbody {
    width: 70% !important;
    div#ja-right {
    width: 30% !important;
    div#ja-main {
    div#ja-left {
    and setting the whole width in templatesja_purity_iicsslayout.css
    /* MAIN LAYOUT DIVS
    .wrap { width: 100%; clear: both; }
    .main { width: 1210px; max-width: 1210px; margin: 0 auto; position: relative;}
    of course i’ll clear the cache, but the template seem not react to my modification,
    hope you can help,
    kind regards,
    Guillaume,
    Nazario A Friend
    #525265
    Hi Guillaume,
    May I know about the tip you mentioned? And how do you want to adjust this template ?
    Please pm me your admin url and credentials so that I can check and help you out.
    folamour Friend
    #526830
    hi i’m sorry to get back to you but i raise a case and get no help,
    my display is now ****ed up, i have tried to play on parameters but the server not react,
    please can you tell me the format the file as to be saved ???? UTF8, Ansi, etc…. ???
    thanks a lot,
    folamour Friend
    #526835
    i have restored a backup of the blog on my xampp lab, (work fine)
    i have uploaded whole japurityII and system folder from template directory to the blog,
    deleted the cache
    disabled the cache (JAT3 & Joomla)
    deleted the file and directory in folder cache
    and the display is still corrupt,
    i’m sorry but i cannot do more
    some help will be welcome
    cheers
    Hi Guillaume,
    I just changed the default layout:
    <blocks name="middle" colwidth="30">
    <block name="left1" >left</block>
    <block name="right1" style="jarounded">right</block>
    </blocks>
    To:
    <blocks name="middle">
    <block name="left1" width="20">left</block>
    <block name="right1" style="jarounded" width="30">right</block>
    </blocks>
    So the left block will have width=20, right block has width=30. Please have a look.
This topic contains 5 replies, has 3 voices, and was last updated by  Saguaros 10 years, 9 months ago.
