  • degakila Friend
    #195469
    Hi….
    I come here to ask some help to change Ja Mags footer position.
    Im a nubie, i don’t about php and coding, i onlu know just little css.
    I was try it by my self and spend 4 days, till this time i could solved it.
    So i come here to find any help, maybe someone here able to give me a help.
    Detail my desire as attc picture.
    Im still in local house.
    Thank you for your kind attention and help!.
    1. position
    Ninja Lead Moderator
    #525450
    You can find and change it from templates/ja_magz/tpls/blocks/footer.php file, see the screenshot
    1. footer
    dpchap015 Friend
    #525452
    if you want to change footer position that u mentioned ion screenshot and for re-size them.
    you need to change the php code from template/ja-magz/tpls/blocks/footer.php.
    (change span size for re-size footer position)
    Hope it helps
    degakila Friend
    #525461
    Hi.. Thanks for respond.
    Ok will try it.
    degakila Friend
    #525564
    Still looking help.
    Im still can’t configute it out
    #525614
    <em>@degakila 414935 wrote:</em><blockquote>Still looking help.
    Thanks</blockquote>
    Could you explain in more details? Any screenshot with explanation would be helpful, I will try to help you out.
This topic contains 6 replies, has 3 voices, and was last updated by  Ninja Lead 10 years, 8 months ago.
