  • tjorvi_hrafnkelsson Friend
    #133112
    I need some help to customize my template from Joomlart for my customer. I have some ideas from some designer, about the look and how it should function.
    But I just want some professional joomla template specialist to help me have this up and running in joomlart template. Does not need to look excatly the same as the design, but have the look and feeling.
    What steps should I take, to make this happend?
    Menalto Friend
    #269551
    First you should decide if the help you want is paid or free, if paid you should post it in the paid section, if not post it in the section for the template this is about.
    In any case you should describe what you want done and how it should work, post some screenshots also.
    anisjolly Friend
    #269660
    Another option if you’re looking to have it done paid is use http://www.joomlancers.com
    This is a subsidiary company which falls under the win of J.O.O.M Solutions (which also owns JoomlArt).
    Joomlancers allows you to pay freelancers to do all the work you need doing. Freelancers bid to do your project (of course you set the budget) and then they go through the project with you as and when the project is progressing.
This topic contains 3 replies, has 3 voices, and was last updated by  anisjolly 16 years, 4 months ago.
