  • dkabbey Friend
    #168948
    I might have done something wrong here: http://cheetahgeneration.com/index.php/en/ has a total structure! Would you please help!
    Thank you very much!
    TomC Moderator
    #414937
    <em>@dkabbey 270477 wrote:</em><blockquote>I might have done something wrong here: http://cheetahgeneration.com/index.php/en/ has a total structure! Would you please help!
    Thank you very much!</blockquote>
    Ben:
    Can you clarify what the specific issues/problems you are experiencing are?
    dkabbey Friend
    #414940
    Sure! When I type: http://www.cheetahgeneration.com
    The site comes up different! I would truly appreciate your assistance. The overall structure/template comes up wierd!
    TomC Moderator
    #414943
    It looks to me like you haven’t enabled certain configurations for the .com site as you have on the .org site
    dkabbey Friend
    #414944
    Thks! Are there any specific things I should enable? Please let me know!
    TomC Moderator
    #414945
    <em>@dkabbey 270491 wrote:</em><blockquote>Thks! Are there any specific things I should enable? Please let me know!</blockquote>
    Well, one way you could go is have the site Administrations up for both sites and cross-check each module to make sure the settings are identical – if that is what you’re going for.
This topic contains 6 replies, has 2 voices, and was last updated by  TomC 13 years, 3 months ago.
