  • redlight_traitor Friend
    #117353
    There is no guide on how to make the transmenu work! I already did the “edit html” and put in “3” to use the transmenu but it still doesn’t work on my site. Please tell me how to make submenus, etcc….. I am totally lost! Thanks – Johnny
    btw, my site is http://www.mfuz.com if you need to check it ou
    Hung Dinh Friend
    #210900
    Hi Jonny,
    Admin >> Menu Manager >> Mainmenu
    Then click on any menu item (Eg: newsflash), you will see there is Parent Item setting for the menu. You will choose the parent menu for “newsflash” via this settings. You can set “Home” as the parent menu.
    #210906
    OOHHHHH OK, I got it!
    Noobs: here’s the detailed instructions:
    For the transmenu, pick “3” in the index.php file
    and then go to your menu, and add another menu item, and inside the item options….there’s a scrolldown list for you to pick a parent. Instead of leaving it at TOP which is the default, pick another item on the same menu and you will see that the new item will become a child item under the parent via the transmenu effect!
    thanks joomlart, you guys rock!
    Hung Dinh Friend
    #210911
    redlight_traitor,
    Glad you did it ! feel free to post whenever you need help
This topic contains 4 replies, has 2 voices, and was last updated by  Hung Dinh 18 years, 3 months ago.
