mihirc Friend
mihirc
- December 2008
- 95 times in 39 posts
February 16, 2009 at 2:07 pm #138192Hello All,
This has got actually nothing to do with Joomlart, but i thought maybe i should just post it on the forum maybe somebody has an idea.
I have officially been given over a development of an component that was made for Joomla 1.0. My first target is to make it compatible to J1.5 first by legacy, then stable.
I have managed to get it installed. But then the errors start coming. First is while installing ->
XML Parsing Error at 92:56. Error 4: not well-formed (invalid token)
Under it comes -> Component Install Success.Sadly, the component install success part is just a fake, because even though the files are installed and put in the right folders, mysql db created, there are no submenus in the components>book library part. Attaching a screenshot for reference of both J1.0 and J1.5
I have already spent 2 days looking at the code, and now am lost.
Any help would be greatly appreciated.
Regards,
Mihir Chhatre.questbg Friendquestbg
- May 2008
- 339 times in 197 posts
February 16, 2009 at 2:43 pm #291785Hi Mihir
Really wish I could help, but this is way beyond me!
Having said that, this looks a really interesting project so I’m happy to now be subscribed to this thread now!
Good Luck
Chrisquestbg Friendquestbg
- May 2008
February 16, 2009 at 2:46 pm #291786Hi Mihir
Good Luck
Chrisscotty Friendscotty
- March 2008
- 827 times in 595 posts
February 16, 2009 at 3:03 pm #291789See it the XML validates here… http://www.w3schools.com/dom/dom_validate.asp
mihirc Friendmihirc
- December 2008
February 16, 2009 at 3:05 pm #291792Hi,
It does validate.
I tested that a long time back.
Regards,
Mihir C.mihirc Friendmihirc
- December 2008
February 16, 2009 at 5:25 pm #291813<em>@questbg 112563 wrote:</em><blockquote>Hi Mihir
Good Luck
Chris</blockquote>Hello Chris,
Thanks a ton. Once we get these issues sorted out, and have a dedicated website, the first version of the component will be out.
I would forward for all your comments.
Regards,
Mihir Chhatre.wooohanetworks Friendwooohanetworks
- September 2008
- 138 times in 41 posts
February 22, 2009 at 7:19 pm #292887Hope you fix that soon, I also need to migrate a combined plugin and module to 1.5 stable, in this case from legacy to stable, however you like to see it. When you can share some information about the migration, like a tutorial you know etc. as the one “Removing a legacy Pt. 1 to 3” is not very detailed, I think some more users would appreciate it.
Thanks!
shertmann Friendshertmann
- September 2008
- 42 times in 26 posts
February 23, 2009 at 6:34 pm #293098hi mihirc even i have not in the develop joomla component task, i am php developer so maybe i would give you a hand. so if you want sent me a pm
This topic contains 8 replies, has 5 voices, and was last updated by shertmann 15 years, 9 months ago.
