tfosnom Friend
tfosnom
- October 2010
- 200 times in 94 posts
September 23, 2011 at 12:52 pm #168865Hi all
I’m testing an 1.7 version of Ironis for suitability to task. I need to put a thin long bar (graphic) into the top black area between
top.left & top.right positions. I have made a custom module containing text as a test and published to top.topbar position (which exists), as this seems central, but nothing is showing up? Any clues how I do this please??
Blessings Shanejooservices Friendjooservices
- October 2014
- 1245 times in 1121 posts
September 23, 2011 at 3:09 pm #414470Hi
Would you mind explain some more detail and give me your site URL ?
Thank you
Viet Vutfosnom Friendtfosnom
- October 2010
September 24, 2011 at 4:53 am #414574Hi Jooservices
Thanks for your help, I wish to place a new module on the top black area of JA Ironis between the existing “login and account creation modules (top-left) and the top-right (social network icons)in the top-right positions. Looking further into this today, I believe I need to create at the template level a new position, midway between the above mentioned modules.I attach a few screenshots to assist.
jooservices Friend
jooservices
- October 2014
September 24, 2011 at 5:01 am #414575Hi
You forgot your website URL 🙂 Than i can’t check it 🙂
Please update it
Thank you
- October 2010
September 24, 2011 at 12:19 pm #414649Hi Joomservices
Thanks for the offer to assist, I appreciate it. Didn’t forget to include the url, the site is local on wamp. sorry should’ve mentioned that. 🙂 it shouldn’t be necessary to view my site just to tell me how to add a new module position at that location? When I have done support here in the past (under a different user name) I’d just install a local copy to debug on saving time and communication.Shane
- October 2014
September 24, 2011 at 5:10 pm #414692Hi
In this case, would you make full site screenshot and note on it what are you wanting ?
Thank you
Viet Vu -
Viewing 7 posts - 1 through 7 (of 7 total)This topic contains 7 replies, has 2 voices, and was last updated by tfosnom 13 years, 3 months ago.
