July 10, 2017 at 6:06 pm #1047367
hi
The template is ja intrant.
When i use the same template with Hwdmediashare it is not showing buttons properly. When i enable beez it is showing properlyregards
Saguaros ModeratorSaguaros
July 11, 2017 at 9:15 am #1047642Hi,
May I know in which page I can see the issue with the button?
July 12, 2017 at 11:29 am #1048085This reply has been marked as private.Saguaros ModeratorSaguaros
July 13, 2017 at 4:04 am #1048274It seems that 3rd party extension is using old version of Bootstrap v2 while our template is using Bootstrap v3 and it causes the conflict in style. Could you try to contact them if there is version supporting Bootstrap 3? (as Bootstrap version 4 is coming soon).
July 13, 2017 at 7:02 am #1048316thanks for the support we will take it from there
AuthorPostsViewing 5 posts - 1 through 5 (of 5 total)This topic contains 4 replies, has 2 voices, and was last updated by shravan 7 years, 2 months ago.
