  • Diego Friend
    #173264
    Hi i have stocked with the customization and need some tip.
    First i need to fitt Ja-Kranos with new style.
    This is the sample pdf required http://miratuproyecto.com.ar/cereales/pdf.pdf and the demostration site is http://miratuproyecto.com.ar/cereales
    i´m stock with the round corners i use now border-radius but ie not recognized. I used a file. htc did not work, a bit of javascript and nothing.
    I never used T3 and I’m a little complicated.
    On the other hand the background of the page should be # 3D6B4F and I can not create images of the slideshow they are three (bg-mask.png, bg-mask-left.png, bg-mask-right.png) do not know much about image editing I tried to change the color image saturation and approach but do not get the exact color.
    I need help please. Thank you very much.
    Any suggestion is good received.
    instantinlaw Friend
    #436239
    Hi hertak,
    PM me your login info and ftp and I’ll see if I can help
    instantinlaw Friend
    #436591
    You did PM me that you were all set now, correct? Let me know. Thanks
This topic contains 3 replies, has 2 voices, and was last updated by  instantinlaw 12 years, 10 months ago.
