  • rossm Friend
    #182066
    I need help with a front page grid problem in the mobile view.
    Here is a link to the dev site:
    http://www.treetopwebdesign.com/clients/armada/index.php
    user: ja
    pass: jaForum12
    I am using Joomla 2.5.8, JA University 1.3, YT Widgetkit 1.3.1, PPC Simple Spotlight 2.7
    I need to have a rotating banner that is 75% wide and a random image loader that is next to the banner that is 25% wide. I am currently accomplishing this with the responsive YT Widgetkit (rotating banner) and the non-responsive PPC Simple Spotlight (random image loader with links). I have created a custom HTML mod and am using the following code published in the user-5 position.
    Mod:
    <div class=" grid-2">{loadposition sliders}</div>
    <div class=" grid-3">{loadposition spotlight}</div>
    Template CSS:
    . grid-2 {width:75%; float: left; display:inline;position: relative;margin: 0 5px;}
    . grid-3 {width:20%; float: left; display:inline;position: relative;margin: 0 5px;}
    This will allow the banner and image to be displayed in the 75%/ 25% configuration. However, when viewed in an iPad and iPhone the random image module gets cutoff and doesn’t display correctly.
    I have tried many css grid % and px combinations and many widget kit combinations but can’t seem to get it right.
    I can deal with the following solutions:
    1. Both the banner & image are responsive to the display
    2. When the display gets small the 25% image moves below the 75% banner image
    3. When the display gets small the 25% image is not displayed
    Any suggestions as to how I can keep the 75/25 layout and still have a good mobile display are greatly appreciated.
    Thank you!
    HeR0 Friend
    #472366
    Hi Rossm,
    That is javascript problem of YT Widgetkit . I have seen that it set height and width for elements incorrectly. You should get YT team help you or try to display 2 blocks = 100% to get your issue fixed.
    Regards,
    rossm Friend
    #472438
    Hi HeR0,
    Thanks for your reply. The problem is that the User5 position (the top panel) is set up for a 25% grid. When I publish 2 mods it wants to make then each 50% width. I need to publish 2 mods and select a 75% and a %25. This would work if I was using the “Content Mass Top” (75%) and the Position 5 (25%) but they are already being used below.
    Any other ideas? Is is possible to add in another ja-container easily?
    HeR0 Friend
    #472868
    Hi Rossm,
    Please try to create 2 new positions in a spotlight as below
    <block name="top-spotlight" type="spotlight" special="left" specialwidth="75">banner-1,banner-2</block>
    Then create 2 custom modules assigning to banner-1 and banner-2 position.
    User guide: http://wiki.joomlart.com/wiki/JA_T3_Framework_2/Guides#Custom_width
    Regards,
This topic contains 4 replies, has 2 voices, and was last updated by  HeR0 12 years ago.
