JA developer,
The page still has a too much space under the slideshow and under the top menu. The slideshow pictures should be flush with the breadcrumb. Also, it still has too much space in the content and each of the modules, and under each of the articles. The space appears to be added at the bottom of every module and article.
Also, I get an Error on Page which says ‘this.el.offsetWidth’ is null or not an object, ja_tabs.js, Code 0, URI: http//www/protetcanyon.com/plugins/content/ja_tabs/ja_tabs..js
The change fixed the gap between the bottom user menus and JA module, though.
Is there a way to correct the extra space and get rid of error?
Thanks so much!
