  • optionsizzle Friend
    #139137
    I am having two issues with IE. The first is when i post articeles up, the first 1 or 2 articles are the correct text size but, when i post more those that were the right size move to the bottom of the page and become larger text. This only happens in IE and not any other broswer and i have checked everywhere for an answer.
    The second is the bottom menu and footer come out of place when you click on an article. again, this only happens in IE.
    I need help fast since most of my vistors use IE.
    1. joomlaissue
    2. bottommenu
    #298095
    Dear optionsizzle ,
    please kindly send me live url of your site , i want to have a closer look on the problem.
    optionsizzle Friend
    #299934
    Hainn,
    Did you have time to look at the problem I have been waiting for a solotion.
    Josh
    ayakomaru Friend
    #300557
    Hi. I am having trouble with IE too.
    can you please take a look?
    http://www.ayakomaru.com/cms
    Thank you so much
    optionsizzle Friend
    #300560
    ayakomaru
    You will need to include more info on your issues than just putting here is my site i have issues with IE. So other members would be able to help you.
    As For the issue with the Footer problem I had it was because of a module i was using that was putting it out of place.
    As for the font problem Ja purity uses percentages in the CSS if you simply change the pecentage to the specific font size like 18px then that should fix that issue.
    I also like to thank joomlart for there non response to any of my inquiries for help and would make me second guess buying a premium membeship.
    ayakomaru Friend
    #300561
    Thank you for the reply.
    If you open my site (http://www.ayakomaru.com/cms) with IE, you see things all over the place.
    I do not know what the problems are.
    Maybe it happened when I changed the fontsize, or header size??
    It seems like many people are having trouble with IE, and there are no cure yet?
    I keep looking, though…
    Thank you
    ayako
    ayakomaru Friend
    #300573
    I downloaded IE developer toolbar, and it told me what i did wrong, so my “broken” part was solved now, but I cannot figure how to retrive logo image.
    my site is
    If anybody can help, i will really appreciate
    Thank you
This topic contains 7 replies, has 3 voices, and was last updated by  ayakomaru 15 years, 7 months ago.
