  • cgarb Friend
    #124349
    My site, http://www.thecampusword.com, uses JA Teline and I would like my user menu to show up below the default menu that comes with JA Teline. Can I receive some help doing this if it is not too hard? Thanks you very very much in advance!
    Chase
    Menalto Friend
    #234587
    It stwo ways of doing it:
    1: you can use the dropline menu, which gives you a menu below the menu,but that is for every item.
    2: you can add a module position below, and set that to show on the “user” pages with the usermenu module.
    I have done it on a original Teline but it needs a little bit clean up, but i see you have changed your some so it might fit right in.
    Give me an email or try to reach me on skype and lets talk there?
This topic contains 2 replies, has 2 voices, and was last updated by  Menalto 16 years, 11 months ago.
