  • vineyardseashell Friend
    #181227
    Hi there,
    C/would someone help me fix the issue I’m having with JA Typo. I added the ‘special list 3 check marks’ to a text list in a module, resulting in the check marks and text being squished together. I don’t know how to fix it so that everything is nicely and appropriately spaced.
    Thanks in advance,
    Vineyardseashell
    1. Checkmarks
    tfosnom Friend
    #469287
    without seeing the actual URL it’s hard to tell if it’s a simple need for some spaces in the text inside the module or the module needs to be wider or some css padding to the typo code?
    Check all three
    Cheers Shannon
    #469303
    Hi Shannon,
    Thanks for the tips. I’ve checked the module spacing- it’s OK; I’ve played around with every setting I could find in firebug, but wasn’t able to fix it.
    I’ve had ongoing issues with <li> lists in other templates too. I don’t know if they are not compatible with one of my components, but whenever I create a list with bullets everything appears to be way off i.e.) margins, padding, etc. I’ve added all the code tweaks I know of to combat the glitch.
    Right now, I’m stumped.
    Many thanks for your help though, I do appreciate it 🙂
    Vineyardseashell
    tfosnom Friend
    #469342
    Again without a live url to use firebug on I’m in the dark want to give us the results of the firebug ‘inspect element’ so we can search the relevent code and .css file?
    Cheers Shannon
    Ninja Lead Moderator
    #469430
    You can change code and css here
    Code:
    <blockquote>plugins/system/jatypo/jatypo/typo/index.html</blockquote>
    Css:
    <blockquote>plugins/system/jatypo/jatypo/typo/typo.css</blockquote>
This topic contains 5 replies, has 3 voices, and was last updated by  Ninja Lead 12 years, 3 months ago.
