  • Sam Kanj Friend
    #130569
    How do I get rid of the quotes and the dark highlighted background above the header images. PLus I cant seem to place a slidshow where the header images go. Can someone help.
    #258530
    Hi kanjart !
    You can replace header image by Slideshow following way below :
    – Go to admin >> extensions >> module manager >> JA Newsflash –> set for JA Newsflash to disable
    – Install Slideshow module ( example : JA Slideshow ) then set for it enable and set position of it to “user5”
    nordland70 Friend
    #258538
    How do I change the text in the quotes: Nulla ridiculus etc.. ?
    nordland70 Friend
    #258539
    <em>@nordland70 65002 wrote:</em><blockquote>How do I change the text in the quotes: Nulla ridiculus etc.. ?</blockquote>
    Ooops.. Nevermind.. I fount it.. Silly me.. :::SOLVED:::
This topic contains 4 replies, has 3 voices, and was last updated by  nordland70 16 years, 4 months ago.
