  • morpheus21 Friend
    #134499
    Hi, I’m making a community based newspaper for an NGO and I decided to use JA_Purity because is very easy in its customization and have many options that looks clean enough to be used as a newspaper template.
    The problem is that when I used the http://www.yoursite.com/index.php?tp=1 trick or the same other one http://www.yoursite.com/index.php?tp=2 to view the modules positions in my template version there is a module called breadcrumb missing, but in some Joomlart demo http://demo.joomlart.com/contest_opt/index.php?option=com_content&view=article&id=19&Itemid=66&tp=1 there is that module position that is not present in my template. I used the last version of JA_Purity and my joomla installation is 1.5.7
    I want to know how can I activate that module position or if this is just a module position that were just included in old versions of this template. The idea is to put a slideshow with some news or images from the published news in that position over the general Frontpage area where the articles starts. Like the banners that come with other templates.
    The module position that is missing in my template installation is called “breadcrumb”
    Here is a picture of the template installed in the JoomlArt DEMO with the module in its place:
    This is my template installation with modules visibles but the breadcrumb one is missing
    I will really appreciate any help or recommendations to solve this problem.
    Thanks in advance.
    nhiepanhvn Friend
    #275945
    You should activate this module in admin’s modules manager at breadcrumbs position. Maybe there is a unknown reason, the module has never activated or placed other position in template.
    Please check again
This topic contains 2 replies, has 2 voices, and was last updated by  nhiepanhvn 16 years, 1 month ago.
