So i need help with getting the PMS on my fireboard forum set up.
I enabled the PMS MyPMS and Pro plugin, and everything but when i choose that under the fireboard pms section it wont work!
anyone know how i can set up my pm system?
Im trying to use UDDEIM
everything shows up fine but as soon as you attempt to click the actual “PM” link. this comes up
<blockquote>SQL errorDB function failed with error number 1054
Unknown column ‘autoresponder’ in ‘field list’ SQL=INSERT INTO jos_uddeim_emn (status, popup, public, autoresponder, autoforward, autoforwardid, userid) VALUES (0, 0, 0, 0, 0, 0, 62)
SQL =
INSERT INTO jos_uddeim_emn (status, popup, public, autoresponder, autoforward, autoforwardid, userid) VALUES (0, 0, 0, 0, 0, 0, 62)</blockquote>
help please
