November 7, 2008 at 12:32 am #135148
I have just installed the JA Teline template. I have joomla 1.5 setup. I was just wandering how or where do I go to change the template from left to right. I need it for arabic language. I want to make everything appear right justified. If anyone can shed some light on this topic would be grateful.
- 2008 times in 1700 posts
November 7, 2008 at 3:31 am #278383Hi kanjart,
The below is my guide:
+ Open template.css file in templatesja_telinecss folder, add the below code at bottom file:
div,ul,td {
text-align: right;
}+ Open ja_news.css file in modulesmod_janewsja_news folder, about line 192, replace code:
.jahl-newscontrol {
position: absolute;
top: 0;
right: 0;
padding: 5px 0;
display: block;
}to
.jahl-newscontrol {
position: absolute;
top: 0;
left: 0;
padding: 5px 0;
display: block;
}Hope it helps.
October 7, 2009 at 7:29 pm #319790Thank you for your recommand.
but now, I seriously need to know how I can rtl the Teline III.Sincerely,
HamedOctober 12, 2009 at 5:48 pm #320261Hi on the same subject . When i div , {text-align: right;} the icons of the Janews2 module overlap the section titles . how can fix that ?
April 13, 2010 at 5:21 am #340178I do have the same problem.. Look at the PIC. The icons of the Janews2 module overlap the section titles
Sherlock FriendSherlock
- 2478 times in 2162 posts
April 15, 2010 at 3:30 am #340410Dear aalgarni,
Please post here your url ,I would like to have a closer look on the problem then I will guide you how to fix.
April 15, 2010 at 7:13 am #340431I also have the same issue as aalgarni. Would very much appreciate knowing how to fix this.
I should note that I moved the section-headers of News2 to the right by adding
.ja-zinsec h2 {
margin: 0 !important;
padding: 5px 0 !important;
font-size: 110%;
text-transform: uppercase;
float: right;
}Is this a wrong way to do it?
April 15, 2010 at 9:18 am #340452Dear fighthatred,
Please post your url in here for checking !
<em>@fighthatred 174667 wrote:</em><blockquote>I also have the same issue as aalgarni. Would very much appreciate knowing how to fix this.
.ja-zinsec h2 {
font-size: 110%;
float: right;
}Is this a wrong way to do it?</blockquote>
April 15, 2010 at 11:12 am #340466Hi dathq,
I’m currently referring to a test-site I’ve just set up at http://www.filousy.com/jom
I’d appreciate any help you could give!
Aratype FriendAratype
- August 2007
- 98 times in 6 posts
April 15, 2010 at 11:30 am #340467fighthatred,
Your site is not RTL, it is only a mirrored LTR… and will cause a lot of justification problems…
I think JA team will collaborate with me to do a real RTL templates
Just give me some days to organize this collaboration with and I hope that JA team accept it…
April 16, 2010 at 1:50 am #340523Dear fighthatred,
I have checked your site but did not see the problem “the icons of the Janews2 module overlap the section titles”.
April 16, 2010 at 12:48 pm #340580yes, i manged to fix it but still have a problem when i click on the setting icon of the Janews2 the setting form dont cover the whole area. please have a look
April 16, 2010 at 7:24 pm #340604actually i managed to do it : all it takes is to change to : text-align: right; in the template_rtl.css
May 21, 2010 at 5:00 pm #344286<em>@kanjart 89750 wrote:</em><blockquote>I have just installed the JA Teline template. I have joomla 1.5 setup. I was just wandering how or where do I go to change the template from left to right. I need it for arabic language. I want to make everything appear right justified. If anyone can shed some light on this topic would be grateful.</blockquote>
i can help u if you want, just look to my site 🙂 http://www.god-i-l.com
AuthorPostsViewing 14 posts - 1 through 14 (of 14 total)This topic contains 14 replies, has 9 voices, and was last updated by godil 14 years, 7 months ago.
Need help with RTL
