December 30, 2015 at 6:06 pm #835243
Hey,
Need help on couple things:
Where I can change logo? See picture. I want to change picture logo, not text what now is.
Where I can change this homepage banner text "World wide experiences…etc"?
Is it possible to change this 4 small pictures in front page, see second picture.?
Also problem with my menu. Menu works right only when I click first navigations–>megamenu(menupicture2) . If I dont click megamenu all menu works like menupicture1, there is no drop navigations.
Thank you,
Juhani
- TomC Moderator
TomC
- October 2014
- 3155 times in 2495 posts
December 30, 2015 at 6:21 pm #835254CHANGE LOGO from TEXT to IMAGE:
Within your Template Manager (JA_Mendozite – Default) – click "T3 OPTIONS" and then click the "Profiles" Tab. Under "Global Settings" – change the Logo Type to "Image." Save Changes.Then, within file path —> /templates/ja_mendozite/css/template.css
at line 834, you will see the following CSS rule:h1.logo a { background: rgba(0, 0, 0, 0) url("../images/logo.png") no-repeat scroll left center; display: block; height: 35px; width: 329px; }
Change the image file path within the "background" property to the image file path for your logo image.
December 30, 2015 at 6:32 pm #835268Sorry I dont understand.
So where I can find this line 834? And also how I know right file path?Thank you!
TomC ModeratorTomC
- October 2014
December 30, 2015 at 6:47 pm #835273Open your Template Manager . . .
Click "Templates" in the left column
Click the "Ja_mendozite Details and Files" link in the center list
Click "css" in the left column list
Click "template.css" within the left column list
Scroll down to line 834 and make changes
SAVE CHANGES
TomC ModeratorTomC
- October 2014
December 30, 2015 at 6:50 pm #835281To change the "World Wide Experiences" title (which is an image) . . .
Within file path —> /templates/ja_mendozite/themes/orange/css/mod_jaslideshowlite.css
at line 13, you will see the following CSS rule:.ja-ss-mask { background-image: url("../images/slide-mask.png"); }
If you want to change the image, you will need to create your own. After doing so, you can then replace the image file path (above) with the image file path to your new image. (If it were me, I would simply overwrite the original image – that way you don’t even need to change the CSS rule).
SAVE CHANGES
TomC ModeratorTomC
- October 2014
December 30, 2015 at 6:54 pm #835290To change the four small pictures on the front page, please refer to ITEMS 12 – 15 within the JA Mendozite User Guide —-> https://www.joomlart.com/documentation/joomla-templates/ja-mendozite#extensions-config
January 1, 2016 at 3:06 pm #836585This reply has been marked as private.January 3, 2016 at 12:06 pm #837259This reply has been marked as private.January 3, 2016 at 12:12 pm #837284Hey,
I still have problems how to change the logo.
I rename now old logo, then upload new logo with that old logo name.
Still in page there this mendozite logo, what is wrong?
See attachment pictures, is there something wrong in css code?
Thank you,
Juhani
January 3, 2016 at 3:23 pm #837344
Hey,
Logo problem finally solved, I didnt realize that I have to change logo to orange template image css.
But now it works.
Maybe im getting there, slowly… 🙂
-Juhani
January 3, 2016 at 8:36 pm #837536Hey,
No have question with K2 menu.
When you click this "yritystiedot", and it opens this page. How you can delete all this, super users, latest from super user and leave a comment? Or where I can modify this contents?
See pictures.
Thank you,
Juhani
Pankaj Sharma Moderator
January 6, 2016 at 3:39 am #839690Hi
You need to check K2 settings for this . Open the item view settings and disable the options > http://prntscr.com/9mn1fg ( enable/disable on respective K2 Category > Item view options.)
or disable it from globally from k2 component optionsAlso i request you to for different topic open a separate thread it will help other users to search same solution of issue .
Viewing 12 posts - 1 through 12 (of 12 total)This topic contains 11 replies, has 3 voices, and was last updated by Pankaj Sharma 8 years, 9 months ago.
Need little bit help?
