robynt Friend
robynt
- May 2009
- 4 times in 1 posts
September 24, 2011 at 7:08 pm #168914In 1.5 Methys – how can I make my right column wider? I would put the link up but it is not ready and I don’t want public links at this time. I will message the link to anyone willing to help me! Thanks so much!
TomC ModeratorTomC
- October 2014
- 3155 times in 2495 posts
September 24, 2011 at 7:47 pm #414724<em>@robynt 270216 wrote:</em><blockquote>In 1.5 Methys – how can I make my right column wider? I would put the link up but it is not ready and I don’t want public links at this time. I will message the link to anyone willing to help me! Thanks so much!</blockquote>
Message link me 😎1 user says Thank You to TomC for this useful post
TomC ModeratorTomC
- October 2014
September 26, 2011 at 12:12 am #414933Here is how you can increase the width of your right column . . .
– Go into your Template Manager (in your site Administration)
– Click on the “Layouts” Tab
– In the “Default” row, click the “Change” icon
– Look for the following code . . .
'</blocks> <blocks name="middle" colwidth="22" fixheight="1">
<block name="content-mass-top" type="modules">content-mass-top</block>
<block name="inset2">left</block>
<block name="right1" width="30">right</block>
</blocks>
Play around with the <block name=”right1″ width=”30″>right</block> parameter until you arrive at the width you want..
(make sure to save your changes and refresh your site page to see results)e.g., change “30” to “40” and see how that looks. If you want it wider, play around with the numbers.
Let me know if that works for you.
robynt Friendrobynt
- May 2009
September 26, 2011 at 1:32 am #414941Thanks Tom…I will try that!
TomC ModeratorTomC
- October 2014
September 26, 2011 at 2:18 am #414947<em>@robynt 270487 wrote:</em><blockquote>Thanks Tom…I will try that!</blockquote>
Let me know if it works for you.😎
robynt Friendrobynt
- May 2009
September 27, 2011 at 2:52 am #415181Tom,
That worked great! Thanks again for the help! It must be a percentage of the page, not pixels.
TomC ModeratorTomC
- October 2014
September 27, 2011 at 4:40 am #415194<em>@robynt 270774 wrote:</em><blockquote>Tom,
That worked great! Thanks again for the help! It must be a percentage of the page, not pixels.</blockquote>
Exactly !!Glad I could help !!
This topic contains 7 replies, has 2 voices, and was last updated by TomC 13 years, 1 month ago.
