  • freddyfish Friend
    #153547
    I need som help to center products in module “latest products”, “random products”.
    I looked throug the template_css.css but it does not seem to can be fixed there.
    I found a site that seems to have solved the problem: http://www.getupandgrow.com/Maternity/Bags-Accessories.html
    This is my site where I am working on where the problem occurs: http://www.planeetblauw.be/pb3/index.php?option=com_content&view=article&id=18&Itemid=79
    Thank you very much
    You can get item styled in center by editing the tempate_css.css file:
    Find the following code:
    div.module,
    div.module-grey,
    div.module-dark,
    div.module-blank {
    margin: 5px 0 10px;
    padding: 0;
    float: center;
    clear: both;
    width: 110%;
    replace with:
    div.module,
    div.module-grey,
    div.module-dark,
    div.module-blank {
    margin: 5px 0 10px;
    padding: 0;
    float: center;
    clear: both;
This topic contains 2 replies, has 2 voices, and was last updated by  Saguaros 14 years, 4 months ago.
