  • laurepr Friend
    #117823
    I tried to use transmenu on the left side of the template. I did install the module.
    But, look : http://leroy.philippe2.free.fr
    Could you please explain me how I can do for the menu to at the left side (!) of the left colone ???? then, why is the sub menu so far from the menu ?….
    Thaks for helping. I hope I’ve been clear enough…excuse my english !!!
    Khanh Le Moderator
    #212179
    There’s a document about JA Transmenu here:
    http://www.joomlart.com/addons/components_and_modules/transmenu_update_to_v.20_for_both_joomla_and_mambo.html
    The text at the first menu item (Administration du site) is quite long cause the submenu display abit far from the main level.
    In the Transmenu module configuration in Administration panel, there are some other parameters which you could change to adjust the position of the submenu .
This topic contains 2 replies, has 2 voices, and was last updated by  Khanh Le 18 years ago.
