  • dfirsching Friend
    #187214
    I am using JA Droid for Joomla 2.5. I need to add a small piece of css:
    .config_Paypal_IPN {
    display: none !important;
    When I use Firefox to insert this as a user stylesheet, it has the desired effect. I am using the red-color profile and the red theme.
    But when I put it into the template.css (either core or red), it has no effect.
    This is to override display generated from JEVENTS RSVP Pro. Need to keep from displaying some sensitive information.
    Any suggestions? Thanks!
    Hi dfirsching,
    You can disable compress css in template manager then post url of page where you want to hide that information. I will check for you.
    regards
This topic contains 2 replies, has 2 voices, and was last updated by  Saguaros 11 years, 8 months ago.
