  • arjwad Friend
    #145522
    I need to insert a <Read More> tag in 2400 articles on my site – basically break up all articles into `introtext` and `fulltext` at the 100th character mark (non code).
    Can someone please help with suggestions on how to do this using SQL. I am guessing a mass update from the phpmyadmin will be a lot quicker than manually doing it in all articles.
    A couple of thoughts I have so far
    A)
    1. Transfer all data from `introtext` to `fulltext`
    2. Move first 100 characters from `fulltext` to `introtext`
    B) – Transfer data from `introtext` to `fulltext` from the first 100 characters onwards
    Would appreciate any help with cracking the SQL. Haven’t played with the language since 2001 🙂
    Context – am upgrading from Teline II to Teline III, and teline II auto broke content in section and category display. Will look through the backend files of teline II to review how they did it as well, however any hints in the right direction would be appreciated.
    Kind regards
    Arjun
    arjwad Friend
    #321716
    This is what I have so far
    UPDATE `jos_content` SET `fulltext`= `introtext` WHERE `id`= 1943;
    UPDATE `jos_content` SET `introtext`= CONCAT( LEFT( `introtext` , 100 ) ) WHERE `id` =1943
    Any suggestions how I can now remove the first 100 characters from the `fulltext` leaving the rest intact…
    Anyone with cleaner, easier methods please also share…this is the first approach I thought of experimenting with.
    gray Friend
    #321720
    I can propose only with PHP
    [php]
    $intro = SUBSTR($article, 0, 100);
    $end = STRRPOS($intro, ‘</p>’);
    $article = SUBSTR($article, 0, $end) . ‘<hr id=”system-readmore” />’ . SUBSTR($article, $end);
    [/php]
    arjwad Friend
    #321724
    Many thanks for your response, but I do not have access to the server to run php commands, they reside with the host – godaddy.com
    Also, interestingly there is another concern, what if an image tag or any other piece of code comes within the first 100 characters…something I hadn’t anticipated earlier.
    gray Friend
    #321728
    If you have Joomla installed you can manage to run PHP code through a component, plugin etc.
    As regards image tags, you are right. It’s one more proof that only PHP could help in this case.
    strip_tags could be used for temp “clearning” of the code from <a> tags to count first 100 characters of the text.
    arjwad Friend
    #321799
    Thanks again, I went through the extensions gallery on joomla.org, and couldn’t locate anything that was rated very high by users.
    Could I trouble you once again to recommend something.
    Arjun
    axiauk Friend
    #321806
    Hi Arjun,
    If you are looking pure MySQL query I just tried this to import my all old articles from 1.0. I am posting 2 different options which I considered.
    1)
    UPDATE jos_content SET
    introtext = ((SELECT SUBSTRING_INDEX(jos_content.fulltext,'<p>’,2)),
    jos_content.fulltext = ((SELECT REPLACE(jos_content.fulltext,introtext,”));
    2)
    introtext = ((SELECT SUBSTRING(jos_content.fulltext,1,200)),
    The first will find 2nd <p> tag in article and copy data upto that tag into intro text and replace that same text with ”(empty) in fulltext to prevent repeat.
    The second query will fetch first 200 characters and do the same for fulltext.
    I hope that will help.
    arjwad Friend
    #323142
    For others who wish to do this in future. Pls note the steps:
    UPDATE `jos_content` SET `fulltext`= `introtext`;
    UPDATE jos_content SET introtext = (SELECT SUBSTRING_INDEX(jos_content.fulltext,'<p>’,2));
    UPDATE jos_content SET jos_content.fulltext = (SELECT REPLACE(jos_content.fulltext,jos_content.introtext,”));
This topic contains 8 replies, has 3 voices, and was last updated by  arjwad 15 years ago.
